Washing machine help
14 Jun 2006
West Glamorgan
I have recently bought washing machine but no hot water pipe, installation guide suggest fitting 3/4" sealing cap on hot water pipe. Currenting got T - Section. Have bought 15mm compression cap from B&Q to small so tried 22mm too big. Any ideas :?: :?:
What do you mean by "currently got T section"?
If the pipe supplying the hot water washing machine valve is 15mm copper, you can use the 15mm stop end. Turn off and drain the hot water from the pipe, undo the compression joint on the upstream side of the valve and then use stopper bit of the stop end in conjunction with the nut and olive left on the pipe.
