Why?Thank you. I was hoping that wasn't the only option
Were you hoping for a less effective and simple solution ?Thank you. I was hoping that wasn't the only option
So what could be simpler than a 32mm insert in the T?I was hoping that there was one with 40mm on the straights and 32mm on the t. Apparently not
They are for hose pipe?![]()
Dark Gray PVC Reducing Tee 3-Way Connectors Water Pipe Reducer Coupling Adapter | eBay
PVC Reducing Tee 3-Way Connector Hose Pipe Coupling Adaptor. First, applying glue to the inside of pipe fittings and the outside of pipe; Second, insert the pipe to the pipe fittings within one minute.www.ebay.co.uk
Thought it was worth a look to see if the sizes where there she wanted.They are for hose pipe?
