I had a gassafe plumber come and change my heating pump recently and after he'd finished it I noticed an electrical crackling sound which at first I thought was coming from the pump. The sound got worse and worse with some loud pops happening. After a while the plumber realised it was the 2-port valve below the pump and we could see sparks coming out of it. He said it just needed to dry out because water had spilled into it when he removed the pump. Now 2 days later its still doing it. I took the cover off and can see the sparks are right at the bottom of the unit between the outer casing and whatever is close to it on the bottom. The valve does seem to operate as normal but I am not prepared to leave the electricity to it turned on incase it starts a fire.
I would appreciate any advice on what could be wrong and what I should do about this.
