Hello,
I am well into a project to renovate a bathroom,
Question 1; I am wanting to install a water supply to the property to replace the lead pipe, a contractor tells me that the supply would not have to exit inside the property but could actually exit inside the attached garage - true or a tall tale?
Question 2; the hot water supply pipe from the combi boiler is 15mm some point through the house it is stepped to 22mm - I know the pressure is the same but surely this would slow the flow rate?
