Hi, I fitted a new immersion boiler(old one leaked), thats ok, the hot water supply was fed about half way down the old immersion and the new one didnt have a hole half way so i got a 'salamander S type top entry flange'.
It goes through a powered pump, then a 'check valve' then to the upstairs, you pull a string pull when you turn on a hot tap upstairs to activate the pump and water normally comes out, it worked once now i get the pump coming on ok but no water,
HELP please.
HELP please.
