QUESTIONS:
1. Is polyurethane or vinyl tube resistant to urine and possible mildew?
2. Is it possible to tap into ABS pipe (drill threads into ABS and screw in fitting)?
REASON:
I just acquired a Falcon waterless urinal for installation in my home. I would like to avoid a permanent installation because I want to remove it easily before I sell the house (not everyone appreciates a home urinal).
I am building a stand for the urinal to sit on. It has a flat base and will be easy to accomplish. I will not have to cut into the wall and permanently mount it.
The issue is connecting it to the ABS drain pipe under the floor. The only effluence from the urinal is the urine itself, no water. For my temporary connection (which could last up to 3 years) I was thinking of using a flexible 1/2" hose out of the back of the urinal through a small hole in the floor, tapped into the ABS.
Am I setting myself up for failure?
Thanks for any assistance you can give.
REASON:
