Ok, please come up trumps on this one!
We originally had a mixer shower fitted in our new en-suite, and the "plumber" took the cold supply off the mains(the en suite replaced a kitchenette in a granny flat, hence mains supply). We spent months and money heating our cold water tank in the loft becuase of the pressure through the pipes, not to mention the amount of water that backfilled into the header tank, then overflowed into the garden.
To remedy this I was told a pump would be fitted, the originaly supply pipes to the shower would be capped, and new flexi pipe used, taking the cold supply off the header thank, and the hot off the cylinder. I guess I should have investigated the matter at this point, instead of trusting that the different plumber (who had fitted new rads through the house and seeemed to know what he was doing) did actually know what he was doing
The pump was fitted in the loft, some 12 feet from the header tank, with the cold feed only having a couple of inches drop to the pump, the hot was taken off the outlet at the top of the cylinder, then up to the loft and into the pump. All worked fine for about two months (not sure how when I've read the instruction manual to find the pump should be below the cylinder not in the loft) but now the pump wont come on at all! I've done all the fault finding bits, cleaned filters, checked and changed fuse in plug, but still get nothing. It was most recently coming on, but stopping after about a minute, and now I've found time to try to sort it out, I get absolutely nothing.
I am fast sinking into despair on this one, as the shower has not worked properly now for a year!
HELP.....Sue
HELP.....Sue
