There is one motorized valve in cupboard- it is Lifestyle Mid position valve.
Programmer is Barlo Products and model is EPR-1
Boiler is Trianco Gas,model W.M. 30/40 R.S.
Thanks for the info. Sorry I didn't reply sooner but DIYnot was crawling last night and I gave up.
I have found some info about your new RF Stat which means that I now suggest you mount the receiver at a lower lever, so the indicator lights are visible if necessary. But before you fix the receiver in place, you need to check that the two parts of the new stat have good radio communication. Attach a lead with a 3 pin plug to a length of cable and connect the other end to the L and N terminals of the receiver. Then plug into a socket and get someone to hold the receiver in the proposed location. Put the controller in its proposed location (where the old stat is?) and check that the two communicate (instructions in the Manual).
Your existing Programmer will still be used for Hot Water. The new stat will take the place of the Heating side of the existing programmer and the existing stat.
Now for the wiring.
Turn power to heating system OFF
Remove the lid from junction box
Now identify the following terminals:
Power in Live
Power in Neutral
Motorized valve White
The terminal for the White wire will have a second wire connected. This wire and the others in the same cable go to the existing stat so they can all be disconnected.
You will need a three core (plus earth - not used) cable to connect the receiver.
Connect Receiver L to Junction box Live IN
Connect Receiver N to Junction box Neutral IN
Connect Receiver 1 to the terminal with the White wire.
Turn power ON and check if the boiler lights when just
heating is on. If it does, that's the job done.
If the boiler does NOT light, Turn the power off.
Insert a short length of wire to link the Receiver L terminal to the C terminal.
Turn Power ON and check again.
The cable to the old thermostat is now dead, so you remove the old stat from the wall if you want to.
