We had the above boiler installed 2 years ago as part of a new extension. The only issues we had to start with was the pressure would occasionally fail and more water would need to be put in the system (4 times 2 years). Last december we found the hot water would not stay at a constant hot temperature.
The water gets to temp on the boiler then the boiler cuts out and the water gets cold then hot and cold etc.
We called Weissmann and their guy cam around and swapped the Heat exchanger plate saying the system had debris. This didn't fix the problem and he advised a system power flush. The power flush was done at the time of installation so we were a little concerned this needed doing 2 years later. Our plumber came round and flushed the system and stated that they didn't think it was as not much debris came out and the problem wasn't fixed! 2nd weismann guy came round and swapped a diverter valve and gasket? this fixed the fault and hot water came back.
3 weeks ago the problem appeared to come back although not as bad yet. Called Weissmann their guy came round said there was debris in the system and swapped the heat exchanger plate. I said this was what the first guy did and probably wouldn't work but he insisted and the problem wasn't fixed! He said the boiler hadn't ben cleaned and showed me black water coming out the system. He also agreed to swap the bottom half of the boiler and told us to get it cleaned.
New part arrived and was installed still no fix engineer said the heat exchanger was blocked and needed cleaning (turns out he had a fused an external controller on the heating system). So now we had not hot water and no heat in the house and snowing outside 2 children under 3 etc... Next day our plumber arrived noticed the Weissmann guy had fused the controller and got the heating back on cleaned the boiler and released a stuck valve in the system no fix for the hot water. Phoned the Weissmann engineer who then stated the heat exchanger plate was now blocked by system debris and that they would not help any further. My plumber removed this and washed through. small particles came out but not enough in my limited experience and his considerable experience to cause a block. hot water was back but cooling to luke warm rather than cold!!!! Now four days later hot water is doing the hot cold thing again and getting worse. We have no idea what to do other than new boiler which we can't afford and we can't afford to pay our plumber to keep cleaning the system.
Any advise or help would be greatly appreciated as we are desperate..
