Hi guys,
Just a quick question to check and see if im being a pri madonna. Got a call from a guy saying his oil boiler was leaking and he wanted his boiler serviced. There were 3 problems with this job.
(1) The boiler house came right down tight on the top of the boiler so i couldnt get in to clean it out properly.
(2) The back yard drain was blocked up and the whole yard was covered in a scum which was i assume decomposed food and sewage!!!!
(3) The oil tank was empty so couldnt check if the bottom outlet was leaking.
Its a student house so i reckon they have tipped the tank and cracked the bottom outlet hence the oil leak. Couldnt really see any leaks around the boiler but i didnt feel about too much due to point 2 above.
I walked away from the job anyway. Did i do the right thing?? Would you charge for this???
Yours still finding his feet
Grill
Grill
