Good Afternoon All,
I couldn't find a section dedicated to garden plumbing so hopefully this will be ok here.
Im looking to create a "wet play" system for the kids which will involve several water endpoints which will spray arcs of water of sprays, whatever I want to add really, anyway that's the easy bit.
So the question(s) really revolve round pump / pipes / tubes / connectors & solenoids.
I originally thought several 12V pumps for each endpoint but I figured they wont be anywhere near powerful enough.
My current plan is something like this, its just something in my mind really so far, not pin pointed exact parts etc :
Water tank with auto level replenishment > either a submerged pump or an output to an external pump > 1" pipe connected to 1/2" 12v solenoids > pipes to endpoints.
I'm thinking a pressure gauge on the 1" pipe feeding the solenoids to monitor pressures.
Not sure if I should include a pressure valve to feed back to the tank if no solenoids are open or an electric system with another solenoid to open when all endpoints are closed to ensure pressure dosnt build up as I assume this could damage the pump? Unless they have some sort of automatic cut off.
So the main questions :
Submerged 750w - 1000w odd pump or ??? external pump? Which would be better if any?
Found a good looking 1/2hp external pump on ebay for £30 odd but it said 35L/m where as the 1000w submerged appear to be 208L/m odd, not sure why there is such a large difference?
Solenoid back flow or some sort of pressure valve? Baring in mind we want as much pressure as possible to shoot water up in the air / in large arcs across the garden.
Any thoughts on sizing of pipe / distances etc I should be aware of?
Thoughts on solenoid control?
Any other thoughts / advise?
Budget is about £75 for parts, which seems to be about right going by my parts list so far, possible more like £100 once I have researched the best way to control the solenoid timings for patterns etc.
Hopefully that is enough info to go on if you would like to know anything else please just let me know.
Regards,
Aidan
Regards,
Aidan
