I'm fault finding my Heatslave 25 combi oil boiler.
The problem announced itself by going into lockout and there's no oil pressure showing at the burner head (I fitted an oil pressure meter). The burner is a Electro Oil B11.
So far I've. .
1. Checked the oil supply to the oil pump which is good (I loosened the inlet and there's a good flow).
2. Replaced the oil pump (which includes a new solenoid) - but still no pressure shown on the oil pressure meter. A new pump apparently comes set to 150 psi.
3. Bled the oil pump by loosening the pressure check port next to the pressure adjustment port - there's an oil flow when the boiler's operated.
4. Ensured that the photo cell was clean and well seated in the burner.
5. Changed the burner nozzle (done as part of the annual service).
If I run the boiler with the pressure monitoring point cap on the burner removed I get a little oil if I cover the hole but certainly no real flow which backs up what the oil pressure meter is telling me.
Any advice on what to test next?? I thought that maybe the control box (it's a TF830b) maybe was not supplying enough power to open the solenoid properly but can't work out how to get inside it to check the relay contacts or to test if this is the case.
The other thought was the oil pump coupling to the electric motor (why are they made out of plastic???) - it's worn but I think good enough (I've a new one on order) - but is the coupling likely to cause these symptoms and if so is there any way of verifying that it's indeed the cause.
Fixing this is becoming a priority - any thoughts? - I need a shower . . .
So far I've. .
