WF540 -more silly lights!
14 May 2008
Hertfordshire
My Hotpoint WF540 has gone bonkers. When I connect to the mains the off/on lamp comes on. I can cancel it, but after about 16 seconds it comes on again flashing quickly, the 3rd and 4th lamps flash less quickly, the water inlet opens and the pump runs. I don't know for how long it does this -I can only stop it by unplugging the machine.
Any help would be very welcome!
that means error fo3 ntc loose or not connected remove lower rear panel and see if the 2 blue wires are connected to the heater . if they are you need a new power board and epprom around 100 .00 ,call hotpoint all parts and labour are 90.00. the choice is yours . :)
javascript:emoticon(':D')
Very Happy
Thanks Rocks! All now OK. I had the drum out to replace the bearings and I think that 'Molex'style connector must have had a tug which loosened the staked-in wires. Thanks again. Tony.
