Hi, with a loft conversion due in the near future I'm starting to research various boiler systems. At the mo we have a conventional boiler on the ground floor, hot water cylinder on the first floor and could water tank in the loft. House currently has 1 bathroom with shower powered with a water pump. The loft conversion will add an ensuite shower room and obviously the cold water tank will have to go.
I'd like a boiler system to enable both bathrooms to be used at the same time with no loss of hot water. My research suggests an unvented cylinder would probably be best...but only if there is suitable mains water pressure. What are the options if mains water pressure is low?? Have an electric shower in the loft ensuite and combi to power everything else? I ideally don't want an electric shower. Any advice greatly appreciated.
Mike
Mike
