They're both made out of the same material, and if anything T&E sheath is thicker
Proper grommet strip, or at least the stuff I've encountered, is a lot more flexible than T/E sheath - I think it might have been butyl rather than PVC.
Yup.I used round head screws on the p clips. I didn't think it made too much difference inside the adaptable box, but I'll go back and change them if you like
That'll be the younger ones.It's a scouts and guides meeting hall. It's constructed almost exclusively from timber, and has a bit of a rodent problem, which is virtually impossible to prevent.
There are dozens of makes of DIN rail terminals - all sorts of options available, but the basic through terminals all look pretty much the same - what is it about those particular ones which interests you?I would be interested in knowing the names of those connector blocks and the enclosure.
4G1 & 4G2It was mentioned that MI runs hot, how hot?
Was taught that micc glands should never be terminated with locknuts, had to use couplings and male bushes with the pot enclosed in the coupling.
Not sure why, perhaps it was to protect the pot.
ban-all-sheds";p="1578903 said:I would be interested in knowing the names of those connector blocks and the enclosure.
I was looking at some din rail connectors and they were open on one side. by that I mean you could see the cable going in and the clamping mechanism. When you tightened the screw it pushed the clamp out a little. I could not understand that. I will see if I can get a picture of one in case you don't understand what I mean.
Hmm have not got the hang of this quote thingy, I wanted to quote BAS
