I was advised that a plumber would split the system into3 zones,one for each floor.He proposed to run 22mm to each level and then branch off to the rads in 15mm.There will be 7 rads in a large 3 bed terrace,using a Vaillant Ecotec plus 831(28 kw),with a single bathroom.The branches will be no more than 5 metres.
Does this seem feasible?I should add the guy seemed very knowledgeable and transparentI will be fitting the wet side but he will be tackling the gas supply and boiler.
