what size
It says 150mm, so providing it fits through the hole should not be a problem. You may need a slightly bigger hole for to go through without snagging.
But as you say you already have 6 inch hole so try it, with a 150mm one.
173mm is the diameter of the front of the fan. The diameter of the spigot (which goes through the wall) is 149mm.
