I need 2 padstones 100x200x100 DP Concrete padstones. Where can I get this size of padstone ? (My local merchants only stock other size which are too wide for my wall which is 100mm block).
You can use concrete pre-stressed lintels, which are available in many sizes (including 100mm). All you then need to do is to cut it to your required length.
A possible alternative is to use engineering bricks laid where required.
If your work is under building regs, consult your inspector about youre idea.
Hopefully, should be ok.
The only problem could be the depth of the lintel. See what he says.
The main job of a pad stone is to take the point loads of large beams/lintels etc. Without the padstone they could fracture/ crush the blockwork.
Just for info, my building control guy said a concrete lintel is fine, and that the 200mm length I was quoted by my structural engineer is an absolute minimum, so I'll make them 300mm long.
