Hi, I have purchased this socket
Which i want to install on the opposite side of the wall of this available under-counter socket
Which has this 13amp fused switch
I have also purchased an RCD adapter, as my intended installation is to drill a hole through the wall, connect the cable to the socket, the other end to a plug, which goes in to the RCD which then goes in to this socket.
Does this appear to be correct?
I copied this idea from the many outdoor socket kits that are out there, but worked out buying the parts separate is cheaper, just need verification on the cable.
From the limited research i've done, would 240v 16amp 3-core 1.5mmsq cable be ok to use?
The use of the double socket is intended purely for lawnmower / garden tool / pressure washer use.
Thank you
Thank you
