Whirlpool wiring
23 May 2005
Liverpool
Going to wire up a whirlpool tomorrow, and just want a bit of additional info please.
I have searched other threads on this, just want to clarify a few things.
The bath is right next door to airing cupboard, in this cupboard is a shower switch for electric shower.
Is it just a case of me drilling a hole through cupboard, coming under bath and pushing flex through into cupboard, running a SFCU or FCU from the shower switch to join cables?
The shower is protected by RCD in CU, will this also cover me for RCD protection?
some other threads seem to be arguing about a whirlpool needing a seperate RCD?
Any thoughts?
How are you going to get 2x6mm² or 2x10mm² cables into the load side of an FCU?
good point, thats another thing previous threads was mulling over,
How would you suggest then?
if you must spur off the shower cuircuit then the easiest way is probablly to use a DP mcb in a modular box
the mcb should have plenty of terminal capacity to take 2x10mm in one end then just run suitable cable from there to the whirlpool bath.
I forgot to say in original post, another option open to me is the immersion heater is no longer getting used, there is 4mm cable running from this back to CU
That sounds like a much better solution. Unless you can find a passing ring main?
