The case seals on Vaillants are very old news, this was happening years ago.
We came a cropper with the first of our ecoTEC installed base last year. The MIs detailed a servicing procedure on the boiler where the burner gasket had to be inspected and replaced if cracked, along with the case seal. It listed a part number for both.
So we went out, found the burner seal had cracked, removed it (it fell to pieces) looked in the box we had brought with us bearing the MI s part number - and there was none there. Also the burner gasket didn't fit, it was for the ecoMAX.
So if you come across an early ecoTEC eg: late 2005 do not follow the MIs that were sent with the boiler, they have now been revised.
In our case Vaillant had no burner seals in the UK (along with HRPC etc etc) and we had to plunder one from a new boiler we had in stock to get the customer working next day.
On the heatstore combi discussion, whilst it is true that when the HS runs out, you are back in poor flow rate territory, some of these HS combis only peg out after 190-200 litres of run off -eg: Viessmann 333.
Surely, many unvented cylinders are installed with this capacity and when they run out, you have nothing for at least 20 mins. So are we not splitting hairs here?
