Will this brick need repointing ?
10 Feb 2021
I am having beams installed to support a chimney stack. I noticed that whilst this beam was being installed the rear wall which the beam was to be placed on was broken through . The builder left it like this, could this lead to possible water damage in the future and should I insist that it is fixed. Also any recommendation on how to reach it to fix it as it seems rather small for scaffolding. Thanks
  • Brick.pdf
You would be better getting the builder back to finish the job properly.
Access would be a problem to diy.
Ditto the above.
You could suffer water damage by the looks of it.
