Hi to all by the way as this is my first post although I have used this site for a while now and always found it to be very useful. However, I need a bit of advice. I am currently wiring in my new oven/hob. Both are electric. The hob will be hard wired using a 6mm cable through a 30amp rated switch. The oven will be supplied using a 13 amp fused spur off the 30 amp switch. On the back of the fused spur the terminals are marked 2 x IN and 2 x OUT. There is no markings for live, neutral on either. There are three terminals at the top of the switch which are marked OUT – IN – OUT respectively and the terminal at the bottom is marked IN.
Question: Does it matter which terminals the wires from the load (oven) are wired to as long as they are wired into the OUT terminals?
I can’t seem to fathom if it matters or not and thought if it did then the terminals surely must be clearly marked.
Sorry if this sounds like a stupid question but I only came across this problem when wiring things in last night.
Thanks for your help in advance.
Dave
Dave
