Hi everyone. I've just installed a new Fantronix TT100T extractor fan, which is an inline type, in the loft. Everything's done, I (just) need to get it wired up. I'm pretty sure I'll be calling someone in to do this, but all the same I'm curious and like to understand what's going on, and would be grateful if you could comment/confirm my assumptions below.
The wiring diagram can be seen on Page 6 (fig 16,17,18) here: http://www.fantronix.com/acatalog/tt_user.pdf
My bathroom light runs on the main lighting ring from the circuit board, with a 6A fuse, and is operated from a pull cord also in the bathroom. This will operate the fan, which has a run-on timer.
- I'm pretty sure that this means the fan needs a 4-core cable with live (brown), switched live (black) and blue (neutral). No earth necessary.
- Am I correct in thinking that this cable is fed down from the loft and wired directly into the terminals of the bathroom light switch? Or would the light fitting be used, rather than the switch?
- Or is there a way it can be taken from the cable in the loft using a junction box, without actually touching the light switch, or light fitting, terminals at all?
That's it for now..!
