Wooden lintel ?
8 Oct 2011
Ive got a house built in 1930's.
The large lounge was originally 2 rooms. While my plans for an extension are currently going through, ive decided to get on with other things on my list.
One of which is re-instating the old wall and knocking through the old doorway into the new room.
After stripping wall paper and hacking of plaster Ive been confronted with rendered brickwork and a wooden lintel that is 115mm wide (4 1/2").
This is a downstairs wall with a brick wall above. It has stood until now but is it suitable to just door line straight into it or does it need re-enforcing with concrete? Im not sure what regs state for existing building works.
Any advice would be appreciated.
If it's only spanning a doorway it will not be a problem (building regs may disagree). If it does need replacing a concrete lintel would be cheapest but a Catnic will be easier to handle.
It is only spanning a doorway and ive noticed that directly above is another doorway so there is no real weight directly above.
will have a closer look as i uncover more.
Cheers
