- Joined
- 9 Dec 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi DIYnot,
We've just moved into an older property (1700s building) with a Worcester 24cdi combi gas boiler. We have 6 radiators total - two upstairs, a towel rail in the bathroom, one in the hall, one in the kitchen and one in the living room. It is a closed system.
The latter two (kitchen/living room) do not get hot at all. They are "drop" radiators (as in, the main flow/return from the boiler is upstairs and these two radiators are fed by plastic pipes that "drop" through the ceiling and T-off to each one).
We have bled all radiators, balanced them, drained the entire system five times from three different drain-offs with all valves open, flushed the two problem radiators by taking them off the wall and putting a hosepipe through them and confirmed all lockshields/TRVs work and function as expected. When we bled the radiators there was a large amount of black/grey water, but none of it was thick or runny. We are confident there is no airlock in the system, as we have been able to put a hosepipe on one drain off and have it push water through the whole system, out of another drain off through another hosepipe.
But there is no sign at all of the "dropped" plastic pipes getting hot - they remain stone cold, whereas the radiators that are before the "drop" in the system get lovely and hot.
The boiler is set to 1.8bar cold, it rises to 2bar after operating for a while.
However, what we have managed to do is get hot water flowing through these two radiators by draining one of them through the drain-off whilst the boiler was on (not advised, I know). This did lead to hot water going to the inlets on each radiator, but as soon as we stopped draining they started getting cold again.
It's a long shot, and my job for next week will be speaking to various CH engineers in my area, but does anyone have any ideas?
