Last week due to the extreme cold weather i turned the central heating water temp up at the boiler a bit thinking the rads could do with getting a bit hotter.
This resulted in the pressure going up a bit and opened the PRV which then resulted in it leaking slowly.
i've managed to reseat it by opening it and letting it release quickly on its own spring tension.
My questions now are.
After refilling the system to .7 bar cold, the presure goes up to about 2.8 bar when fully operational, "It may have done ths before"
Is this too high.
Will the expansion vessel need re-presurising
How do you presurise the EV.
Is it through the Auto air vent at the top of the boiler unit that is accesable or
Through what looks like a shrader valve on the EV that is in-accesable.
Ive no problem will calling in a pro if ness and will do so if the PRV starts leaking again as it looks a sod to get at, I just want to check out all options I can do myself
Is this too high.
