Hi Guys
I replaced the flow and return to the boiler from my house to the garage. I drained the system, hooked up the new pipes, filled the system up to 1.5 bar, vented the rads and switched the thing on. The boiler did not work and suddenly stopped. I took the control panel off and a fuse had blown. Now when I switch on the blue light flashes continually after about 3 minutes. I noticed water had leaked from a bleed valve onto the block that feeds the fan. I guess the fan is blown.........Stupid question but could it be something else? The fan is around £180 so I'm just checking all avenues. Last question......when you switch the boiler on should the fan come on right away. Btw the design of the water above the fan plug is nuts. Btw the boiler is 2.5 years old.
Thanks in advance
Thanks in advance
