Hello All, I am selling house and exchanging in the next week and boiler conks!
The boiler a worcester 28CDi is old and not regularly serviced.
I went on line and looked at the worcester site at the user manual under: INDICATOR LIGHTS
The mains electricity indicator is ON
The Central Heating Demand Indicator is ON
The Domestic hot water demand indicator is FLASHING FAST (5 times per second) the manual says this indicates a: Air flow fault (RSF) or Flue gas spillage
The Flame detection indicator is OFF
# I tried Reset Button and after various clicks it stays the same.
# I checked the Flue which is straight through a cavaity wall to outside and clean as a whistle.
# Water pressure is OK
# I removed the cover and exposed the fan and noticed when I switched the boiler on and off the small fan blades moved 2 or 3 inches then stopped as though it was trying to go.
I removed the fan assembly-no sign of damage and re-installed.
I used a multimeterand checked voltage against the red and balck terminals. When I switched the boiler on at mains, I had 205 volts AC for a few seconds, the little blades moved 2 or 3 inches and then the voltage cut off completely.
Do I need a new fan??? Or is there some other potential problem I have missed.
Should the fan be spinning full bore when it gets the 205 volts and is the fact that the fan is not spinning/extracting causing the lack of "Air flow fault" which is stopping the main burner from firing up.
ALL HELP GREATFULLY RECEIVED WITH THANKS
