Hi. Have a bit of a problem with a slight leak from the diverter valve in the boiler. The water is leaking from the black plastic cover from the micro switch assembly. Is this a repairable thing or has the complete valve need to be replaced?
Does anyone know if the scaling inside a water to water heat exchanger can be removed by one of the comercial descaling liquids you can buy?
Thanks for any help.
Twogun
Twogun
