The hot water at the bar shower goes hot then cold. The shower manufactures sent me a new cartridge to try and this has not cured the problem.
If you run the tap at the basin this runs ok, I ran the shower and watched the flame picture boiler fires up, and does not seem to modulate to me, as it runs for a couple of minutes then cuts off then fires up again. I have been told by the customers they turned the water off when new w/machine fitted, and drained the water from the boiler, but kept the heating on. Could this have damaged a sensor/thermistor ? don't think it is the divertor valve as it fires on demand when the taps are turned on. Any help/ideas appreciated as there are no manufacturers instructions with the boiler thanks p.s hopefully you can now understand my post
