Hi hope some some one can pull me out of the s***........
I have been to a job in a pub on a gypsy site the boiler boiler was in bits ! you know what they are like think they can fix every thing...
When i finaly put every thing back the problem was the boiler when turned on go's though the ignition sequence i.e fan running ,air pressure switch,pump running.try's to ignite it is sparking fine but will not fire up.....
I did all the usual checks and come to the conclusion it must be the gas valve?
step 1.......
So i went ahead and changed it but still the same problem (go's to lock out with a flash sequence of one flash per second.)
step 2......
changed the pcb (still the same problem).......
Hope some one can help as i dont really have much experience on this type of boiler
Cheers...lee[/u][/b]
step 1.......
step 2......
