Just after some advice on my worcester Bosch 24i RSF Combi boiler.
I woke up yesterday to find no heating or hot water, had a look at the boiler and it was not attempting to "spark". Made sure the reset switch was not up (it wasn't) and then went to work thinking I would need to get someone in to have a look.
Just to clarify the boiler had power it would attempt to do something when called for HW or heating, though no spark. For heating the pump started running and so did it after the call for hot water
Came back at lunch to find a working boiler ! Which is great but I'm guessing something must be wrong ?
Looking on the advice on here apparently if there's no spark its normally the fan / flue or the Air pressure switch which could cause this. The fan was replaced last Septemeber and is fairly quiet, so I would'nt of thorght it was that but apparently the original Air pressure switch on these boilers are not particularly reliable.
Anyway just wondering if is worth doing some pre-emptive maintenance i.e. replacing my air pressure switch. Picture below of if, I don't know if this is the original one or not ? (apologies for the poor pic's - camera phone)
So really the help i'm after is do you think it may be the air pressure switch and if so is it worth me attempting to replace it ?
Thanks in advance for any help
Cheers
Andy
Cheers
Andy
