Worcester Bosch Highflow 400 - HW de-pressurises CH
17 Jan 2009
Surrey
CH off and HW off. Run the HW tap and the pressure in the CH drops.
I have a 2nd problem where the CH is drawing in air to the system.
I'm guessing their could be a heat exchanger problem & plan to replace heatexchanged & seals. I'm also suspecting the diverter valve.
Any thoughts ? What is replaced in a standard service ? The boiler is 8 years old.
I have had this boiler do this very thing which is most unusual as the
pressure usually rises when there is a pinhole in the DHW HE!
What I would suggest is that you get worcester out on a fixed price call out to replace this heat exchanger... it is a swine to replace!! They will fix all the faults at the same time!!!
Last time I did it I got the full DHW HW ready assembled with the manifolds and it still took me 6 hrs as I got a leak after I had rebuilt it!
Make sure the top can come fully off the boiler so you can get good access.
The second problem with the air could be anything...you may have a small leak somewhere allowing air to be sucked in but I would reserve judgment until you have had the DHW HE done.... I would also not be changing the diverter valve if there is no problem with the CH working.
Good advice - thanks !!
I have also thought about replacing the whole boiler for a Highflow 440 or 550 but I will ask Worcester to look at the current on 1st.
Before you get too involved I hope you have not left the filling valve open and either have no non return valve or one that is jammed open!
Tony
Agile, good thought but I have become very used to re-pressurising the system lately !
Something has failed inorder for the HW and CH to interact. Heat exchanger is my only thought.
Local plumber suggests that Combi boilers have a life expectancy of 10years approx. Is that right ?
Evidently someone short of work installing new boilers with little skill at repairing them.
I often repair old Vaillant combi boilers that are 20 years old!
Tony
