if there aint a valve between the tank and the heating pipework (follow the pipe ) from the bottom of the tank
it sounds like the cold feed is blocked
Bale out the F&E tank first as the contents will gush out over you when you cut the pipe.
bab said:Another option to try 1st save cuting into pipework is to attach a hose onto the drain off on the shelf below the pump & open it to see if the tank starts to run. if no attach the hose to the drain off with a jubilee clip & attach the other end to a cold water tap. then open up the drain off full & pack with old towels as they leak a bit. then turn on the cold tap a little. go up to the small tank & it may be pushing water out of the 22mm vent back into the tank. try blocking the vent with a cloth & ya thumb & c if the pressure build up will push through the blockage into bottom of the tank. If so turn off the water main close the drain off. try to remove all the gunge out of the small tank then opn the drain & let it run fresh 4 a while, Then treat ya sysyem 2 some desludger & a good flush out. then add inhibiter.
Am i sposed to be doing this with the heating on or off ? As i opened the drain off beneath the pump and absolutly nothing came out icon_cry.gif
Where is the pressure sposed to be coming from ?
Is that the drain i should be attaching the hose and tap ?
