Hi ,called out to a heatslave 12/18 which has been idle for many months.To cut a long story short I got the boiler working.The problem is it is only heating up the hot water.The diverter valve is working as is the pump.All the wiring has been checked all the valves are open everything is getting the right signals.The only thing that could be a problem is the c/h thermostat which fires up somtimes and not others and only seems to run for a few minutes before shuttiing off ,can anyone confirm that it is a faulty stat or suggest what else the problem could be.
Regards,
NACD.
Regards,
NACD.
