We have a 24i which is about 6yrs old. It will produce hot water but no C/H. Once the HW is turned off then then boiler has a little fit and turns off, safety button pops out. The boiler will turn back on if the button is pressed down, but will have the same fit again. If you try and turn the heating on the boiler will make the noise but no action!!!
It sounds like the boiler is producing hot water for the heating and not being able to pump it. You can hear a hissing noise like an outlet valve just before the pilot light stops...
Do you guys have any ideas what maybe going on?
Many thanks
Many thanks
