I want to install a 10.8kw shower, covering the cable in plaster, and sharing part of the route (3 meters) with a ring main (both wires), and 3 meters with an extractor fan spur (2.5mm cable). 3 meters under loft insulation. Total length of cable <13 meters.
Will a 10 mm2 cable suffice?
Is it worth moving the cables to run separately?
Also the wall the wire will be incased in is in Zone 3. Is that a problem?
Many Thanks!
Many Thanks!
