? Same question. i have an NN board and I have to move a light switch. Clearly there's no RCBO available. Can you fit an external RCD spur instead? A possible answer to the original question. Good enough for you?
It is considered very bad form to bring old posts to the top again; usually the original poster has long found a solution to the issue and in most cases no longer posts (although in this case, SB is still around). So an answer is no longer needed on the original thread.
By all means read the thread to establish if it contains an answer to your question, but if you need further assistance it is best to leave it be, and start a new one, otherwise those stumbing across the thread and seeing it at the top of the board end up reading it from the start thinking its a fresh thread...
