Yale Pet Friendly PIR's...how to tell the difference
10 Nov 2013
London
Hi there, I have two Yale Pet PIR's, and two standard Yale PIR's. They have got mixed up, and I need to know which one is which!! How can I do this, without manually putting a cat or a dog infront of them?
Thanks in advance!
do you have pictures of the two types.
also if you look at the installation instructions you should be able to see which ones are for the pet and which are standard.
They look exactly (and I mean exactly) the same from the outside, and I haven't it the instructions
on the inside are they not marked up?
There was no instructions with them, I have been searching online and cant find any, do you have any paperwork on them so I can have a look and see if I can find anything for you.
Right, inside there is just some model numbers and codes, and even if I had some paperwork, I wouldn't be able to distinguish between the pet friendly ones and the normal ones
what are the model numbers should be able to separate them with those and simple online search
