Y
yaleguy3
Before you do a factory reste and just to test the phone connection have you tried controlling the system using your mobile.
ie remotely operating your alarm.
1 Dial the phone number associated with the Control
Panel ( usually your home land line).
2 Hang up on the first ring.
3 Wait 5-10 seconds.
4 Dial the number again.
5 The control unit will now answer the call you
Will hear a beep. (If not repeat the above)
6 Enter your alarm PIN Code within 3 seconds.
7 If the PIN code is correct, you will hear another
beep you are now connected to your alarm.
Once connected the following apply
Press 2 This will arm the system
Press 3 To disarm the system.
Press 5 Check the system status. Long single
beep for Away Armed, two beeps for
Disarmed and three beeps for Home Armed.
Press 7 Siren on.
Press 8 Siren off.
Press 9 or 0 Disconnect.
• Remember to press 9 or 0 before you hang up, or
the control unit will hang up automatically after 30
seconds.
Press 7 Siren on.
Press 8 Siren off.
seconds.
