I am getting error code 90 on the above machine. Having searched for the answer on this site I am satisfied that the connection between the control board and the main cct board is OK. Any idea where I go from here please?
E90 is a "family" error code seen by the consumer (you). To view the actual error code (which could be anything from E91 to E99) would require activating the diagnostic program. I can tell you that all error codes between E91 & E99 indicate communication or configuration issues, i.e; wiring problem, communication problems, pcb failure, or wrong pcb configuration. Have you changed the pcb or panel card recently? If no check ALL the plugs on the pcb and panel card again & examine the plug ends carefully for broken/loose wires. If you require further information post the PNC number....this should always be stated regardless of which type of question you ask.
