Hi all,
Any help/advice would be appreciated.
I have central heating and boiler cover with homeserve. Since last week I've had an intermittent problem where I get no hot water unless I put the heating on. All I have to do is press the heating button for around 30 seconds and then the hot water starts to work. Homeserve sent an engineer out he had a quick look and said he couldn't do anything unless the fault happens in front of him. This is an intermittent problem which happens probably once a day but is solved by putting the heating on for a few seconds, do they expect me to have no hot water until they arrive so they can see the problem !! ?
Any ideas what may be causing this problem so I can get back onto homeserve with some suggestions? The boiler is a Worcester Bosch Combi 28cdi.
Thanks in advance.
Adam
Thanks in advance.
Adam
