Peugeot 307 oil filter.
6 Sep 2007
Hertfordshire
Where do I find the oil filter on a 307? It doesn't seem to hang down on show like other models. The new filter I've bought is plastic with a paper filter in the middle and comes with small rubber o rings. Any tips on where its located and how to change would be appreciated.
Cheers
rob
Is your engine a 1.6 16v, if it is then the filter is to the side if the "Cat", under a black plastic cover.
black plastic cover sometimes has a nut hex shape on top of it
Thats the one - hex shaped nut. Im fine with draining the oil, but how do you take the old filter out of the plastic casing and put the new one in?
Cheers
Undo the hex nut, then simply pull old filter out and replace with new.
