canafind
Joined: 08 Sep 2007 Posts: 3 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Sat Sep 08, 2007 4:35 pm Post Subject: installing dimmer |
Trying to install dimmer in lounge. Currently 2 light are on 1 standard switch. The wiring inside the blue neutrals are joined in a little plastic junction (not sure whats its proper name is) and the live wires go to L1 and L2.
I have bought a single dimmer, and a double dimmer as I\\\'d prefer to control the lights independently. The double I wired the Brown lives to the live connectors top and bottom and the corresponding blue to the ~(with arrow) top and bottom. The lights would not then come on. I have not tried the single dimmer as I was unsure on the wiring. If this is the route I have to take to both neutrals go to the ~ and both lives go to L1. Not tried as I though this would short.
Thanks in advance for any help or advice. |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sat Sep 08, 2007 4:58 pm Post Subject: |
thank your lucky stars it didnt work, it would have gone bang
you seem to be saying you have 2 blue and two brown (since you said the 2 blue are in a connector) is this right? __________________ Do you like music Mr Finch?
Forum = Opinions |
Steve
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Sat Sep 08, 2007 5:13 pm Post Subject: |
RULE ONE OF LIGHTING CIRCUITS!!!!!!
Never EVER connect NEUTRALS to LIGHT SWITCHES!!!
Connecting neutrals to light switches will have 2 results:
1. Toasted switches
2. BANG!
You have 2 brown wires: LIVE and SWITCHED LIVE. The switch simply opens and closes a contact between them (or a variac and other sensitive controls in the case of a dimmer)
By connecting live and neutral ACROSS THE SWITCH you have probably fried its SENSITIVE ELECTRONIC innards.
Given there is only one feed to the 2 lights from this location, if you want to split them onto 2 switches, you will need to do more wiring. |
canafind
Posted: Sat Sep 08, 2007 7:43 pm Post Subject: |
Thanks for the replies.
I have also the single dimmer which I could fit. How would I determine the live and switched live? and to which connectors in the dimmer do they attach?
Thanks |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4934 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sat Sep 08, 2007 7:46 pm Post Subject: |
On a dimmer it doesnt really matter. Convention says the live should go to COM (~) and the switched live to L1 but it'll work either way round. __________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R. |
canafind
Posted: Sat Sep 08, 2007 7:53 pm Post Subject: |
Will try in the morning then when the sun is out and theres enough light to see! |
