DIYnot
Local | Network
   DIYnot > Forums
Local | Network
RCD test button ineffective
Goto page 1, 2  Next
Author Message
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 8:09 pm Reply with quote
Rented flat, about 6 months old (or less).
Single lighting circuit - B6 MCB had tripped. I reset the MCB without any apparent problem, so I replaced three blown 240V halogen bulbs (lamps).
I then checked the RCD (MEM 80A / 30ms) with the yellow test button - nothing happened. Switched RCD off - all protected circuits went off. On again - all circuits energised again.
My advice to the letting agent:
1. Either the RCD or the earth path is faulty.
2. A qualified electrician should be called to replace the RDC and/or fix the earthing.
3. Urgent action is needed, because there's a risk of electrocution if an ECP becomes live.
Was my advice correct?
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 380 times
PostPosted: Sat Sep 22, 2007 8:13 pm Reply with quote
Yes, your advice is correct.The designer of the installation has chosen to fit an 80A/30mA RCD for whatever reason (TT?, Supplementary protection against direct contact etc)
This device has failed its functional test.The mechanics of it have obviously failed which means it could also not trip in the event of an earth fault.
Urgent rectification required.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 8:16 pm Reply with quote
Thanks ricicle.
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 146 times
PostPosted: Sat Sep 22, 2007 8:18 pm Reply with quote
Most certainly the former (or at least its test function), the test button doesn't rely on an earth path (if it did, and the path didn't exist, then presisng the button could cause danger), but rather current is passed (via a resister) from the outgoing phase terminal to the incomming neutral terminal to set up an inbalence in the RCD
Quote:
3. Urgent action is needed, because there's a risk of electrocution.
You have to strike the right balence between stressing the need to fix it, and scaremongering (and it looks like you've got it about right icon_smile.gif ), is this a ground floor flat, and does it have an electric shower?, it could be that there is no requirement to have an RCD, and while if there is one it should work... perhaps its not 'get electrician out of bed at midnight' territory yet icon_lol.gif
Was my advice correct?[/quote]
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 8:29 pm Reply with quote
Thanks Adam.
It's a 3rd floor (in UK terms, i.e. 3 up from ground), and doesn't have an electric shower, but a Megaflo heated by two IHs.
It happened yesterday, and the agent looked to be dragging his feet over getting an emergency electrician, so I didn't want to leave them in any doubt that it's potentially lethal. Since I carried out no tests, especially PAT tests, we don't know if there's an accident waiting to happen.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Sat Sep 22, 2007 9:05 pm Reply with quote
Could be just a broken test button, but has failed a functional test and should be replaced. How dangerous it is depends on what it is protecting and the reason for it being there i.e. is it a TT supply? It may have just been installed as it is considered good practice to protect sockets, possibly becoming a regulation in the 17th ed.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 9:11 pm Reply with quote
It didn't make me comfortable that it was protecting the lighting circuit as well as most of the board. I didn't make notes, but I believe the non-RCD side comprised only the Megaflow related circuits.
The feed came from the basement via SWA cable and appeared to have three conductors - there was a 3P isolator on the consumer side of the meter.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Sat Sep 22, 2007 9:17 pm Reply with quote
I can understand why you are not comfortable with that, it isn't a good idea to protect lighting circuits with the same RCD as sockets etc as a faulty appliance can cut all the lights. IIRC the only lights which currently require RCD protection are those installed in Z1 of a bathroom (bar on a TT system where an RCD will be required for protection against indirect contact on all circuits).
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 9:29 pm Reply with quote
Maybe it's TT. I don't know.
I'll be going back at some point, so I could check. How would I tell?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Sat Sep 22, 2007 9:32 pm Reply with quote
If the earth is from the supply head it will be a TN system, the fact there are things fed from the non RCD side says it is very very unlikely to be TT.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1040 times
PostPosted: Sat Sep 22, 2007 9:35 pm Reply with quote
Softus, there are some good diagrams and stuff in the wiki which may help you to work out the earthing supply type.
electrics:earthing_supply_types_and_bonding:earthing_arrangements
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Sep 22, 2007 9:41 pm Reply with quote
Er, my question was a bit stupid, because I realise now that I knew the difference.
The meter is one of a bank of about 24 in a cupboard in the basement, so I'll go down and take a look at the earthing next time. I was a bit surprised to find that the cupboard wasn't locked, but it looked as though it would take nothing more than a large Allen key to open it anyway.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Sun Sep 23, 2007 2:10 pm Reply with quote
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Sep 23, 2007 2:20 pm Reply with quote
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1459 times
PostPosted: Mon Sep 24, 2007 12:02 am Reply with quote
the test button has no reliance on an earth.
might be the test button is faulty, might be the RCD is jammed. they do that sometimes, especially if not tested for a year or more (though your one sounds quite new)
Edit: Oh, Adam_151 already covered it icon_redface.gif
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Test button on RCCB not working 5 500 Fri Sep 11, 2009 1:48 pm
test button 11 480 Sat Mar 28, 2009 3:09 pm
RCD Test button wont trip 54 1700 Mon Nov 19, 2012 12:01 pm
RCD Test Button Colour 7 760 Tue May 09, 2006 12:37 pm
immersion heater re-set button 2 380 Tue Nov 20, 2007 8:29 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
