DIYnot
Local | Network
   DIYnot > Forums
Local | Network
moving BT junction box
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
flyfto
from United Kingdom
PostPosted: Mon Oct 15, 2007 9:02 pm Reply with quote
hi need to move my bt junction box, there is a 2 core cable coming from bt box outside window to the junction box where can i get this cable from,
not sure if the cable spoke about in other posts is stuff i need.
see pictures (not the best)
thanks in advance for any help
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Mon Oct 15, 2007 10:44 pm Reply with quote
that cable shown in your picture is not something that BT use currently, whether it is a past BT cable type or a diy bodge I can't say but it doesn't look much like phone cable to me.
You aren't meant to mess with BT's wiring but if you must then use CW1308B cable so they can't tell it wasn't them.
Back to top
 Alert Moderators
musashi
from United Kingdom
PostPosted: Wed Oct 17, 2007 2:17 pm Reply with quote
I remember my Grandma having one of those in her house, with an old-fashioned dial type phone. I'm sure that the telephone was hardwired into it, rather than the plug-in sockets that we use today.
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 927 times
PostPosted: Wed Oct 17, 2007 3:30 pm Reply with quote
That does appear to be a DIY bodge from the past. Between BT boxes BT would have used twisted pair cable and not the type shown.
The box shown is the type where the old hard wire phones were connected. If the cover has a square cut out removed at one end then almost certainly that cover was over the lead from a hardwire phone lead.
Someone has removed that phone and wired on to sockets else where.
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 6:27 pm Reply with quote
Hi, I also need to move my BT socket and also have twin core cable coming down from the junction box on my outside wall.
Thanks for the pointer on the cable type to use (CW1308B), but could you please confirm if this cable is ok for outside use, ie coming down the wall from the junction box on the facia, and is there a preferred colour choice for using the wires (I believe that only two wires are used ?!?)
Do you know if Maplins supply the cable?
Many thanks, Carl
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Oct 20, 2007 6:29 pm Reply with quote
Many thanks, Carl
clicky
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 6:43 pm Reply with quote
Thanks Breezer, although Maplins reckon that you cant use the CW1308 cable outside (in their FAQ's). I notice on another post here that it says that you can use the CW1308 cable outside but not inside.......hence the confusion.
Apparently the CW1308B is the prefered choice but Maplins dont seem to stock that one.
Any comments?
Thanks.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Oct 20, 2007 6:57 pm Reply with quote
run it inside, looks neater
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 7:09 pm Reply with quote
The only trouble is that i need to connect it to the BT cable under the guttering outside and run it down the outside wall to come in by the front door to the BT socket.
Would it be ok for this ?
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sat Oct 20, 2007 7:22 pm Reply with quote
For information to you and others i thought i would let you know that i have found this CW1308B cable for about 1 a metre.
http://www.minitran.co.uk/pages/products/list.mhtml?ct=5&sc=31
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Sat Oct 20, 2007 8:01 pm Reply with quote
CW1308 comes in two versions, CW1308 internal for indoor wiring only and CW1308 external for external wiring only (it is not suitable for use indoors because it is filled with a flamable jelly.
CW1308B is suitable for use both indoors and outdoors, unfortunately it seems a little tricky to source the stuff at low pair counts.
If you can go straight into the back of the outdoor box and avoid exposing the cable you could probablly use CW1308 internal for the entire run.
Back to top
 Alert Moderators
JOHNBOY42
from United Kingdom
Thanked: 10 times
PostPosted: Sun Oct 21, 2007 12:59 pm Reply with quote
white cable is only used for inside as it will crack and split under direct sunlight after a few years,black cable ,i.e telephone,satellite ,cable companys only use black outside and can only use up to 3m of this inside the house as if the house goes up in flames it gives off toxic fumes........I know this sounds daft if the whole house is on fire what difference would this make but it is a health and safety ruling
Back to top
 Alert Moderators
wiffers2003
from United Kingdom
PostPosted: Sun Oct 21, 2007 6:59 pm Reply with quote
Does that apply to SKY because they just installed my SKY+ with white cable or is it ok as they use a different type of cable.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 245 times
PostPosted: Sun Oct 21, 2007 8:36 pm Reply with quote
satallite cable is nearly always black and is used indoors all the time, same for SWA mains cable and many other cable types. The blackness comes from the addition of elemental carbon and won't produce anything nastier than the cable would have produced when burning anyway.
The outdoor version of CW1308 must not be used indoors (very short runs to come into a junction box are considered acceptable) because it is filled with petrolum jelly and can therefore accellerate the spread of fire. CW1308B is not jelly filled and is suitable for use both indoors and outdoors.
most cable types can cause toxic fumes, special cables that don't are availible but they are not required for most wiring (the main time they are required is when a cable route is also an air route for a heating/aircon system)
Generally white cables should not be used outdoors because they tend to be sensitive to UV but it is possible to make white cables that are UV safe.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 460 times
PostPosted: Mon Oct 22, 2007 4:36 pm Reply with quote
Put sun cream on them?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Page 1 of 3
Jump to:
Alarm cable terminal/junction blocks? 11 1080 Sun Oct 11, 2009 2:37 pm
Telephone Junction Box 18 4560 Wed Feb 02, 2011 6:59 pm
Telephone Junction Box Query 6 1261 Thu Apr 23, 2009 9:19 pm
BT80a junction box- Any idea where I can buy one? 6 2221 Tue Jul 15, 2008 10:56 am
cable from outside junction box 2 1960 Tue Aug 07, 2007 3:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
