I have a Baxi Solo 2 40 RS that has worked with out a problem for about 8 years. At its last service, repair man said over heat cut out was disconnected (not me by me). He reconnected it. Now it often trips out just after the boiler has a long run. It is a pumped system and manual says pump should run on for a few minutes after boiler shuts down. (It doesn't) I presume this is to prevent over heating?
On gravity system it says to disconnect the over heat thermostat.
My questions are:
Am I likely to be right about why it is tripping. If so is it easy to wire the pump into to run on or do I need to get an extra part fitted to circuit board?
Also if it is safe to have the trip disconnected for gravity feed, is it really needed for pumped system (or how dangerous was my installation without it?)
My questions are:
