DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Hotpoint WD61 not emptying
This topic originated from the How to page called Washing machine troubleshooting
Click here to return to the page called Washing machine troubleshooting.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
colmm
from Ireland
Thanked: 0 times
PostPosted: Tue Nov 13, 2007 7:25 pm    Post Subject:
Reply with quote Thanks
have a Hotpoint wd61 and its not emptying. replaced the pump but still no luck. Any ideas?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Nov 13, 2007 8:44 pm    Post Subject:
Some more information?
Is the drain hose into a stand pipe or onto a spigot under the sink?
Is the drain pump running?
Back to top
 Alert Moderators
colmm
from Ireland
Thanked: 0 times
PostPosted: Wed Nov 14, 2007 11:12 am    Post Subject:
Draining
It is Draining a certain amount as in i emptied 1 basin of water from 1 Spin but then still has plenty of warter left.
Back to top
 Alert Moderators
colmm
from Ireland
Thanked: 0 times
PostPosted: Wed Nov 14, 2007 11:17 am    Post Subject:
clearer
Sry not used to these forums.. But yes drain pump and pies are clear from the pump to waste but water even though is been pumper only realy trickles out but is pumping it out just very slowly so not sure if thats how it normally works?
Back to top
 Alert Moderators
sheer1delight
from United Kingdom
Thanked: 1 time
PostPosted: Wed Nov 14, 2007 11:28 am    Post Subject:
Have you looked in pipework from base of drum to the pump. There might be a piece of clothing such as a sock that has got in between the outer and inner drum and has lodged either in the pipework or where the water leaves the drum.
Back to top
 Alert Moderators
colmm
from Ireland
Thanked: 0 times
PostPosted: Wed Nov 14, 2007 11:56 am    Post Subject:
kinda works :)
KK well i have a test run running atm.. after running the end of the sping 3 times it has finally emptied and so and running a full test if that doesn't empty will have a look there... thank you's for your quick response..
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Wed Nov 14, 2007 1:32 pm    Post Subject:
The filter in the sump hose will be blocked.
Drop the hose off the bottom of the outer tub and clean out the cage in the hose.
Back to top
 Alert Moderators
colmm
from Ireland
Thanked: 0 times
PostPosted: Wed Nov 14, 2007 1:51 pm    Post Subject:
Thank you
Back to top
 Alert Moderators
nocando
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 31, 2007 6:43 pm    Post Subject:
icon_biggrin.gif This forum is brilliant, your advice helped me fix my washer too, thank you very much.
Back to top
 Alert Moderators
Dust
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 05, 2008 1:55 am    Post Subject:
Hi there
I've got the exact same problem with my WD61 too - it won't empty anymore. Now, it's done this twice in the past and I've fixed the problem by going under my kitchen sink, finding where the washing machine outlet plugs into it and giving it a good clean. This time, it was once again really caked up with solidified fat and stuff but removing it and putting it all back together hasn't fixed the problem. I started the wash cycle completely from scratch again and it ran all the way through, yet is still full of water at the end of the cycle.. icon_sad.gif
Forgive my ignorance but I don't know what a sump hose is or where the filter is located. Can someone give me step by step instructions of what I need to do to try and fix this before I have to resort to calling for help and paying through the nose...?
cheers
Daz
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Feb 05, 2008 8:36 am    Post Subject:
Sorry, Don't have the time to give step by step instructions.
The sump hose is on the bottom of the outer tub and goes to the pump.
It may not be the problem however. From your post, you've had fat blockages in the past. If this has gone down the drain hose and solidified at it's lowest point then you'll have a blockage there. Sump hose is easiest to check first. It does involve unplugging the machine from the mains and taking the back off first though.
As to "Paying through the nose". Don't you think we deserve to earn a decent wage?
Take into account the overheads of an office, telephones, heating, lighting, vans, insurance etc and you'll find there's not a lot of profit in this work.
Giving up my time to answer queries for free doesn't put food on the table either.
Back to top
 Alert Moderators
Dust
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 05, 2008 8:44 am    Post Subject:
Very sorry, am new to these forums. Didn't mean to cause any offence and there's really no need to bite my head off.. icon_rolleyes.gif
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Tue Feb 05, 2008 12:46 pm    Post Subject:
Absolutely no offence taken, if there was I wouldn't have answered your query.
I'm not biting your head off, just pointing out the value for money when you do call in an engineer.
Back to top
 Alert Moderators
Dust
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 06, 2008 1:06 am    Post Subject:
Hi again
Cheers for the replies, sorry if I got you a bit wrong there - it was first thing in the morning and I'd had a bit of a sleepless night worrying about the darned thing...
Anyway, I got the back of the machine off and am now seeing this:
http://djdust.com/misc/wash.jpg
Is the sump pipe the black one directly underneath the 'wheel' at the bottom? If it is, I can't see exactly how to get to it to check if it's blocked. Can you help me any further?
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 4 times
PostPosted: Wed Feb 06, 2008 8:43 pm    Post Subject:
Take the black clip off the large hose (yes, under the pulley), pull the hose off (loads of towels) and you'll find the filter cage in there.
If all is well there then either a blocked pump (left hand side) or faulty pump.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
hotpoint WD61 - Not emptying... 8 4580 Sun Jun 11, 2006 9:53 pm
Hotpoint Aquarius Washer Dryer not emptying 3 220 Wed Apr 15, 2009 2:31 pm
Brand new Hotpoint Aquarius not spinning emptying/rinsing. 7 680 Thu Jun 05, 2008 4:14 pm
Washing Machine not spinning or emptying 8 540 Wed Nov 26, 2008 9:01 pm
Bosch Dishwasher not emptying 2 2180 Mon Jan 30, 2006 5:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
