Hi Guys,
I'm currently putting a new kitchen in and wondered if anyone could check that i'm on the right track with the installation of the new electric hob and seperate oven installation.
I'll try and be as informative as poss to give you enough info.
The hob has got 5.8kw stamped on it and the oven 2145w - 2335w on it.
I have gone back to the cable where the existing CCU where the old cooker was connected (which which goes back to the fuse box and has a 30amp fuse on it.) and done the following:
Connected the cable into a 30amp connection strip where i have looped over so i have 2 x 6mm cables running out - 1 leading to new CCU and one to a new 13 amp double plug socket.
So far so good ?
Following the down to the new CCU - i have a 30amp CCU with a plug socket in it - In have 6mm running in and 6 mm running out.
I then plan to run this into another junction box where i will put the 6mm into another connection split so i can have one 6 mm cable running to new oven and one 6 mm running to new hob.
Ive had a quick look around the site and it seems that i might have to replace the CCU from 30amp to 40 or 45amp?? Would this be the case?
Also - all earthes have been shealthed in g and y and cables running horizontially and vertically will be wall sheathed with alluminium wall sheathing (if thats what its called)
I think thats about it - CCU is going to be within 2m of both appliances.
Is there anything fundementally wrong with this approach ?
Thanks for any feedback.
Joe
So far so good ?
Joe
